dry gas seals contamination?
We have a compressor that compresses an associated gas (gas separated from oil). But although all the filtration we always have contamination of the dry gas seals by oil.
What are the possible causes of this contamination knowing that the filtration is by the standards?
Why always the failure happens on the gas seal of the output side?
thanks in advance for your help.
RE: dry gas seals contamination?
Shahab Zardynezhad
