Multiple Values
Multiple Values
I have a rule that sets the multiple values of a parameter(B) based off the value of another parameter(A). Is there a way to set parameter(B) to equal the value of the first multiple value in the list? Whenever parameter(A) is changed, the value of parameter(B)does not change until I select a value from the new list of multiple values.
Thank You,
Kevin
Thank You,
Kevin
RE: Multiple Values
The valuation of Parameter B by a relation may not satisfy the list of multiple values <== message from CATIA KWA.
Then Parameter B list id not avalable no more as Parameter B is defined by if tule.
RE: Multiple Values
RE: Multiple Values
RE: Multiple Values
Kevin
RE: Multiple Values
RE: Multiple Values
RE: Multiple Values
