mirror display
mirror display
the mirror display sill dos't work with solids in nx8.0.3.4. is there a version i can look forward to seeing it work correctly? referring to a post from 12-13-11 "missing mirror display"
RE: mirror display
Also, a link to the other thread you mention would be nice...
www.nxjournaling.com
RE: mirror display
http://eng-tips.com/viewthread.cfm?qid=312410
the problem is if the entire solid you want mirrored falls of the screen it also takes away the mirrored part making it difficult to see if your assembly is actually mirrored. it will keep all curves weather they are on the screen or not.
RE: mirror display
RE: mirror display
It seems that the graphics card dumps the mirror image of the model if the "original" becomes invisible, so the trick is to keep the original visible... ( Yes , really smart
I tried two methods to do this, and both seem to work.
method 1, Use a layout showing two views, then zoom only one to the mirror. ( the other still shows at least the original)
method 2, open a second window ( can be behind / hidden) one of these windows will display the original.
Interestingly, i have a grip program from the Unigraphics V9-ish-time, yep some +20 years old, still working , Using Grip one can define layouts other than the ones provided out of the box, such as a layout with a minimal view in one of the corners of the graphics.
I have been recommended not use these layouts since the current graphics technology is quite different. anyhow it also does the trick, if one dares. ( On the other hand, one must maybe not save after using the layout if it is for design review usage ?)
Attached is a screendump of this "not-recommended-layout-style", a small view in the upper right showing both original and mirror. The main view only displays the mirror.
Tomas
RE: mirror display
i need to see both solids close up to make sure there is no flaw in structure / outline of each detail. some differences may be within 0.25MM on a 20 foot assy. old (nx3) ug had this capability.
cowski,
they say its a culling thing????? not going to get it any time soon. the way i understood it was, it is still open but not a priority, another great feature of ug that went away? anyone else ever really use this function? we use it all all the time here (at least when we could)
RE: mirror display
All you need is a second graphics window, it can be completely obscured by the one you are working in,since it shows the original body,it will force the graphics adapter to keep the graphics data used in the "top" window.
See attached image.
Tomas
RE: mirror display
