Aluminium Beam Design
I've read through our Aluminium Code here in Australia (AS1664.1), and it isn't clear what-so-ever. Not much time has gone into writing it.
Anyway, I've never specified/designed Aluminium before.
I have a small roof to do. Rafters are Aluminium RHS, with Al. RHS struts inbetween like blocking. Basically it won't buckle.
Can I design it as per normal Mild Steel? I.e. Just calculate the stresses in the extreme fibres and ensure it doesn't yeild?
Or am I missing something important?
Obviously E and yeild stress is different, but Ixx etc shouldn't be any different.
Ben
Ben
RE: Aluminium Beam Design
Again this is a different code, and possibly outdated... I would be leery of treating AL as mild steel, if it was that simple then they wouldn't need beam equations in the AL design manual, right?
example calculations for a channel.
Do you make all of those MatchCADS? or is there some share site like steeltools for excel programs?
It's using Mathcad 15 but I printed it as a .pdf so Ben can view it in case he doesn't have Mathcad.
In my case I basically have a small roof that is pretty braced out, so a simple flange yield check and acceptable deflections and I'm good to go. Forces are very low.
One thing they don't explain at all as far as I can tell, is what is meant by "Intercept", "Slope" and "Intersection" values. Stupid question I should know or something not explained too well?
The constants are for different strength curves for each temper of aluminum.
An aluminum construction manual from 1967 is available online here https://law.resource.org/pub/us/cfr/ibr/001/aa.con...
it hasn't changed much at all (I've only gone through it briefly, but I didn't see anything.)
