Problem in starting NX Open API
Hi Frnds
I am using NX-6 with VC-6.
To start API enviornment i used the following procedure
1. Copy All files from
D:\Program Files\UGS\NX 6.0\UGOPEN\vs_files\VC\vcprojects
to
D:\Program Files\Microsoft Visual Studio\VC98\VC\vcprojects
2. Copy the entire folder
D:\Program Files\UGS\NX 6.0\UGOPEN\vs_files\VC\VCWizards
to
D:\Program Files\Microsoft Visual Studio\VC98\VC\VCWizards
3. Set the Environmental Variable MSVCDir
to
4. Start the NX Command Prompt window
5. Start Microsoft Visual c++ from this window using the command "devenv"
While performing the step 5 i got the following error
Errors are also attached herewith
