Broken Enrober
Broken Enrober
I am fixing an ancient Geier enrobing machine for a friend who has a small chocolate factory in Philadelphia. The riser shaft sheared the pin of its drive gear. Now when the riser shaft is rotated, the shaft lifts up 0.5 cm and clunks back down. Any ideas?
RE: Broken Enrober
Mike Halloran
Pembroke Pines, FL, USA
RE: Broken Enrober
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
RE: Broken Enrober
RE: Broken Enrober
A macro photo of the fracture surface might help.
Mike Halloran
RE: Broken Enrober
RE: Broken Enrober
