Raising Crest Elevations
I am looking for suitable material to add on top of the crest and enhance the freeboard requirements as the water level is going up or the crest elevation is abraded by continuous traffic. This is for few small dams (less than 6 m high) with relatively shallow depth of water, which is collected from mining processes.
If the materials have too much fine, there would be problems during raining when driving on the crest. If the materials are too coarse, they would inhibit access and would allow water to pass through if water level goes up. The site may be covered with snow for 1/2 year.
My questions are:
What would be the optimum gradation for the materials?
How much fine is desirable, if granular materials are placed on the crest?
What others do in this circumstances?
Any publication available?
Thanks.
RE: Raising Crest Elevations
Mike Lambert
As for using till, it is possible; all depends on the material in the till. As for a "stabliser", not sure what you are getting at.
One thing that has not been discussed is the purpose of the dams. If they are collecting mine runnoff, then I would expect that discharges could be quite damaging. In which case it would seem that a taller structure would be necessary.
Mike Lambert
look in any highway department specification for aggregate base course and use that. It will have a maximum particle size of about 50 and should be well graded all the way down. do not use natural material such as till, it will not likely be suitable. recommend no more than about 5% silt or clay size particles.
best way to avoid the material rolling down is to make the top of the embankment wider so that traffic is not near the edges. stabilizer then would not be needed. but if this has heavy traffic than you will need to surface dress it from time to time.
other suggestions such as 1000 freeboard are also recommended. maximum anticipated water level should remain below the structural road section.
I understand this is for the materials located above the maximum water level. In fact this will be the materials that will make the freeboard body. So why the fine% should be limited to 5%. As there is a chance of water raising along the freeboard and more fine materials would guarantee a more impermeable freeboard and can better prevent water perclating down the embankment (in the freeboard height. however, the surface rock better to have as little fines as possible. Hope I am not missing any point here as there is also a suggestion to use high fine materials to above the desired elevation of top of the dam. In other words, should the soil which makes the freeboard body be fine or coarse and if there is any recommended gradation. Thank you again to allow me to understand the issue.
I just googled it - I was right about 1010 - not bad after nearly 20 years.
https://www.raqsb.mto.gov.on.ca/techpubs/opsa.nsf/...
