metric drawing dimensioning ?
I have very little experaince with metric. I have a drawing that gives a clearance of
0.56 +8'
what does the ' mean? I am thinking
0.56 -0 / +0.08
would that be correct?
RE: metric drawing dimensioning ?
that sure isn't standard for metric length dimensioning. angular => minutes ?
You better ask whoever made the drawing.
Mike Halloran
Pembroke Pines, FL, USA
8 minutes? feet? lol Yeah better provide more info or the drawing.
DUH...(palm plant to forehead)
The drawing was a scan from an old instruction book. As I cut and paste to make illustration for discussion with customer, I saw it!
I have attached the drawing and now that I know what it is, I don't know how I could have read that as 0.56 +8'
Thanks for the replys
0.56 + 8.7 clearance on diameter free space
Still makes no sense.
Mike Halloran
It is 0.56+0.1 the lower 0 tolerance is too close to the upper 0.1 tolerance that's make it look like the number 8.
Ah. Now I see the 0/0. I still think it's +0.7. Crappy lettering.
Mike Halloran
That has to be it.
the other dimensions on the drawing were all +X, but bearings are normaly given +X/-0
I think as I copied and pasted making the illustraion, some of the clutter pixels cleared up. Or I could have been It was 3am when I first looked at the drawing.
I hope it is +0.1 as that would be a reasonable tolerance for this bearing. this is the first time I have seen drawings from this OEM.
It makes sense for the requirement to read 0.56(-0 +0.1).
It's a strong vindication of CAD, where the text would be much clearer and sharper.
Until your boss prints out a D size drawing on A size paper and faxes it.  Doh!
Think this is [0.56 mm +0.1/-0.0 mm]
The conversion to inches would be:
0.56 mm to in = 0.022 in
0.10 mm to in = 0.004 in
thus:
[0.022 in +0.004/-0.0 in]
The diameter of the bearing is 280 mm = 11.024 in
The clearance to diameter ratio is :
0.022/11.024 = 0.002 in clearance per in diameter
Which is pretty standard for shafts this size.
saludos.
a.
