Model Browser Tree - how to predefine it ?
Hi for all,
I am using Patran 2010 now. Everytime when I open Patran, I have to turn on Model Browser Tree (MBT) and set up all settings.
I want to have predefined MBT - fonts, transparency, turn on filter, size; and I want to have such my custom setting for MBT always loaded when I open Patran.
Do You know how to do it?
I know, that it is not possible to record a sesion file in order to catch manual settings for MBT. Maybe I should add some variables to p3prolog.pcl? or something? I think, that "SimAcademy Webinar Archive: Patran Customization - Tailoring Your Patran Work Environment " could be helpfull, but it doesnot work in http://www.mscsoftware.com/webinars :/ maybe, somebody have it? if so, please give me a link to it :)
I would be greatfull for any help or ideas :)
Best regards,
Mike.
Best regards,
Mike.
RE: Model Browser Tree - how to predefine it ?
I have found something:
function to show BMT is: toggleModelTree()
function to show BMT setup: config_display()
They can be executed in command window in Patran.
My question is: do You know what arguments can be used for toggleModelTree() or config_display() ?
"Configuration settings and other state information (visibility, show transparent RMB option) are stored and retrieved from the patran_conf.ini file." There is also wrotten, that I can find this file in HOME directory or in current directory. I checked that, but I have no such file anywhere :/
My question is: Do You have such file? If yes, please, could You check what is there? I want to know what should I write, when I want to create patran_conf.ini by myself.
