UG/NX Spline to Circle Conversion Macro
Dealing "Edge Geometry" data via a direct Catia 5 to NX translator which NX converts to a spline which by tribal knowledge should be a circle. Is there a NX Macro that converts splines to circles that would be more efficient than defining points on geometry then creating an arc from 3 points?
Thank you for your help in this matter.
Larry
Larry
RE: UG/NX Spline to Circle Conversion Macro
for edges you may look at optimize face doing these repairs at edges and segmentes cylinders
