Acceleration load
Acceleration load
Acceleration load
I need an approach to come up with the longitudinal load induced by acceleration/deceleration of a car body mover in an automobile plant.  The capacity of the mover is 3000 lbs and runs about 450 ft/min.  I would the time to reach this velocity is about 1 sec.
RE: Acceleration load
Here's an attempt at some long lost dynamics skills:
v = v (init) + a * t
450 = 0  + a * 1sec
so, accel = 450 ft/min^2
Then, F = ma
My English units skills are limited (lb force vs lb mass), so I'll pass the torch to the next contributor...
Try this (working in ft, second units only) -
The final velocity is 450/60 = 7.5 ft/sec.
That gives a = 7.5/1 = 7.5 ft/sec^2, which is approximately 23% of gravity. (7.5 ft/sec^2 = 27000 ft/min^2 - the time in trainguy's post should have been 1/60 in minutes).
I don't know the total mass of your mover (including its 3000 lb load), so I will assume that it weighs 4000 lb. in all.  Then the mass = 4000/g, where g is approx 32.2 ft/sec^2.
Thus the average force over the 1 second duration = 4000/32.2*7.5 = 932 pounds force.
Were this my project, I would add a healthy 'ignorance allowance' so that the mechanism had sufficient capacity for the peak acceleration.
OOPS...
I KNEW the math seemed way too easy...
Maybe I should stick to Sum(F) = ma where a=0 (statics).
