How to remove TINY OBJECTS in NX UG?
The part I'm working on is a Curve>Extract from bodies... I would like to delete the TINY OBJECTS (defined as dimension .025 inch) appearing on my window.
Please help!
Please help!
RE: How to remove TINY OBJECTS in NX UG?
the distance can improve / optimze the extracted curves from body on the healed body
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim smallCurves As New List(Of Curve) '%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% '%% curves less than or equal to the following length will be deleted '%% change this value to your requirement Const smallCurveCutoff As Double = 0.025 '%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% For Each tempCurve As Curve In workPart.Curves If tempCurve.GetLength <= smallCurveCutoff Then smallCurves.Add(tempCurve) End If Next If smallCurves.Count > 0 Then Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete small curves") Dim notifyOnDelete1 As Boolean notifyOnDelete1 = theSession.Preferences.Modeling.NotifyOnDelete theSession.UpdateManager.ClearErrorList() Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.AddToDeleteList(smallCurves.ToArray) Dim notifyOnDelete2 As Boolean notifyOnDelete2 = theSession.Preferences.Modeling.NotifyOnDelete Dim nErrs2 As Integer nErrs2 = theSession.UpdateManager.DoUpdate(markId1) End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination '----Other unload options------- 'Unloads the image immediately after execution within NX 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Modulewww.nxjournaling.com
