Failure analysis help
I've got some positive stops that have failed recently. see file attached for dimensions and pictures (10 MB pdf !).
Loads are ~0 to 50 kN, applied according the longitudinal axis of the legs. There is a minimal slope on the edge, so there is a small lateral component.
Parts have been in service for 20 years, meaning about 10^7 cycles.
No fatigue marks to be seen. This is also a failure % of 0.01% (lots of similar components, but not allot of them are 20 years old).
I see a number of welding errors (lack of fusion, not enough penetration).
Is there a way to check if dirt (coolant fluid from bandsaw, mill scale, grease, ...) could have been the original cause of this,
or, which is my opinion, this is just a way too small weld seeing the plates are much larger/thicker.
Your opinions please?
RE: Failure analysis help
I agree, with Corypad, evidence of fatigue in both Fig 7 and Fig 2. I also concur with your conclusion that the welds are much too small for the application, and that there is insufficient depth of fusion (penetration) into those thick members.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
