Assembly drawing on sheet 1 sheet 2 and show the components
I have an Assembly drawing and the exploded view is on the seet one.
Yes I'm new to NX so I add a sheet two now how do I add the other parts of the assemble to sheet 2 and 3 etc. Where do I go so I can select what component/model/part goes on the next sheet.
Thank you
Thank you
RE: Assembly drawing on sheet 1 sheet 2 and show the components
On Sheet 2, add a view that shows the entire assembly. Choose Assemblies -> Context Control -> Hide Component In View. Select all the components you DO NOT wish to see, then select ALL the views in which you do not wish to see those selected components. OK out of the dialog and then update all views. Components that were not showing may appear (like if you have an internal component) - so what I do is usually pick the component I want hidden from the ANT.
You can probably also use arrangements or render sets (of which I'm not too educated at the moment) and View Dependent Edits will also hide the solids if you wish, rather than using Hide Component.
Why would you choose to put all of your drawings in the top level and not with the individual components - unless this is just a special case where you're not making true drawings but just wireframe views for something like an image to paste into a document?
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I don't know which version of NX you are using but you should be able to select which component you want to place a view for in the add view menu.
Following this procedure there is no need to hide components afterwards.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
1. Cilck on BaseView icon (or insert menu/view/base)
2. in Base View dialog box, look at the first section, Part
3. in Part Section, you will have an Open icon. Click on it.
4. now, you can select any part you want. Part of the assembly or anything else.
hope, this helps.
