Problem in Assigning properties in optistruct
Hi all
I am just a beginner in optistruct , I have got a problem with lack of information , while I have created the property : PSHELL for 2D mesh , in the update section of components , when I press comps ,I should see some checkboxes more than surf , like comp-shell , but it's not there , what is the mistake ?
2 - doing another example of the tutorial , automotive control Arm , I arrived to the point to select the nodes for constraints and then loads , but though the nodes where visible in the model , I was not able to select them , using none of the modes possible in node options.
thanks for you attention
