Use 2 materials in one part instead of assembling two parts
Dear all,
I'm working on an axisymmetric rectangular model that has as region with high Young's modulus and a region with low Young's modulus. I modeled it with two parts (one part the high E modulus, one part the low E modulus) and then assembled them together. However, I was wondering if you could also just have 1 part and define two field where each field will have different material properties (here different E modulus). Is it possible? How do you do it?
I was thinking about sections...but I can't find how to define 2 different sections in 1 part.
Thanks in advance!
Thanks in advance!
RE: Use 2 materials in one part instead of assembling two parts
