[NX 8]Title block - populate with list
the new title block, support or via solution / workaround the selection of data via a pre-defined list ? Example list of designers ?
Thank you...
Using NX 8 and TC9.1
RE: [NX 8]Title block - populate with list
the other way can be done with attribute templates, or nxopen
maybe I wasn't clear.
LOV under TC is the same like to set the list in attribute template, with the difference you work on the TC ambient.
Attribute template need to work via file->properties.
NXOpen can be a solution, but very expansive.
I talk about when i double click on the title block or using the 'Populate Title Block' command where the user can select from a list of possible designers if is compiling the cell of the designer.
Thank you...
