GD&T Dimensioning
GD&T Dimensioning
I'm putting a feature control frame with a vertical dimension and I want it to go right under the dimension. Problem is I can't trim off the dimension line to where it won't go through the control frame. Is there a way to do that? I've attached a power-point to help show the issue.
RE: GD&T Dimensioning
This will give you just enough room... wish I knew a better way.
