Whole structure not taken into account
Hello! can anyone help me with a "small" problem. Thank you very much in advance.
I've imported parasolid file (from Pro-E) as one part into Abaqus. Part consists of upper ring, rib, and lower ring. As I've finished analysis whole structure was not taken into account, just "upper ring" which was submitted to load condition. I've entered BC encastre on lower surface of lower ring and between rib and both ring. I've added whole structure to homogenous section and made it independent.
Best regards,
Robert
Best regards,
Robert
RE: Whole structure not taken into account
Luja
Thank you very much for your reply-that could definitely be the problem. Are the merging options so primitive that i must choose either elements to merge or nodes, or am I the only one primitive here? :)
Link
In link/picture it's obvious that nodes are not merged.
