Surface Finish Symbol NX7.5
Is there a way to add the surface finish symbol so it automatically picks up the angle of the face or dimension to which it is applied? I seem to have to add an angle in the settings whereas I would be hoping it would pick up the association of the face.
RE: Surface Finish Symbol NX7.5
Hi Ben.
http://www.eng-tips.com/viewthread.cfm?qid=353583
Yes there is....
In surface finish symbol menu set Leader Type to "Flag" this will snap (select and drag) your symbol to match the angle entity you are placing it on.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
I concur with Nutace ~ the leader menu is just like what is found on the GD&T leaders
