Door Plate / Flush Type Cleanout
I am wondering, is it possible to do a 10ft by 10ft or 8ft by 8ft flush type cleanout? Basically, instead of having a welded door plate, we would like to have one that we can bolt. Anyone knows where to start with this?
RE: Door Plate / Flush Type Cleanout
First question to bat around, does the tank need to comply with API-650? If so, then no, you can't do that, 48"x48" is the maximum.
It would be vastly simpler to put in a large roof opening and lower equipment if needed.
