Dry Utility Question
When working in a an unfamiliar market, what is the easiest way to obtain the names of dry utility companies in the area to ultimately get as-builts for them?
Thank you in advance for any help you can provide.
RE: Dry Utility Question
Otherwise, you could contact the building department and/or public works department with jurisdiction over the project site and ask them which utility providers would serve your project. If there is an environmental impact report or other pre-project study (e.g. a real estate report made for the project owner or a staff report made for the governing board of the jurisdiction), the utility providers might be listed there. Then contact the utility providers (that part you already knew
--Winston S. Churchill
