Changing the folder destination HELP!!!!
In this piece of code the output file goes to the folder where the .prt file is located.
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim outputPath As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim outputFile As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
outputFile = IO.Path.Combine(outputPath, outputFile & "MatingSurf")
I have been trying to do two things with no luck.
First, instead of the same folder I need to go back to a certain folder in the root folder.
N:\CAD Data\DATA\dwr12324\Step Data Release\Release CAD Is where the .prt file is located
N:\CAD Data\DATA\dwr12324\Step Data Release\Mating Surfaces Is where the .prt file is located
In excel I know that I can use the left string to rename the folder detestation but it seems not to work with UG.
RE: Changing the folder destination HELP!!!!
You can still get to the parent directory by using string manipulation commands, but in my opinion, it is easier to use a directoryInfo object. The code below shows one way to do it with string manipulation and how to do it with a directoryInfo object.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        'Get parent directory with string manipulation commands
        Dim parentDir As String
        parentDir = IO.Path.GetDirectoryName(workPart.FullPath)
        parentDir = parentDir.Substring(0, parentDir.Length - (parentDir.Length - parentDir.LastIndexOf("\")))
        MsgBox("parentDir: " & parentDir)
        'Get parent directory with IO commands
        Dim directoryInfo As System.IO.DirectoryInfo
        directoryInfo = System.IO.Directory.GetParent(IO.Path.GetDirectoryName(workPart.FullPath))
        'change "temp" to the directory name of your choosing
        Dim outputPath As String = IO.Path.Combine(directoryInfo.FullName, "temp")
        If Not IO.Directory.Exists(outputPath) Then
            'code to create directory here, if desired...
            MsgBox("The specified directory:" & ControlChars.CrLf & outputPath & ControlChars.CrLf & _
                   "does not exist. Please create the directory and re-run the journal")
            Return
        End If
        ufs.Disp.CreateImage(outputFile, UFDisp.ImageFormat.Jpeg, UFDisp.BackgroundColor.White)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
This is great!!! now what if i wanted to remove characters from a file name?
