Merging multiple journal files into one process!!!!!! HELP!!!!!
I have 5 journal files that I would like to join together. run into errors when I attempt to do so.
Journal file #1: Changes all faces to color 103
Journal file #2: allows you to select certain faces and changes them to the color RED.
Journal file #3: allows you to select certain faces and changes them to the color Green
Journal file #4 automatically creates a jpeg of the screen and then saves it to the in common folder.
Journal file #5 automatically creates a step file of the part in use and saves it to the in common folder.
I would really like to make this into a smooth process. allowing for a no pause just a msg box that prompts change faces to red and a ok button, then another msg box and button for green.
I have attached all the journal files i have created. If anyone can offer some assistance that would be greatly appreciated.
Thanks in advance!!!!
