1950s era stainless clad PV plate
Can any of you oldtimers recall what was the going technology for cladding 1/8" thick SS on steel plate? In this case it is grade 405 (ferritic SS) on an unknown grade of carbon steel; it is not welded.
If roll bond is the answer, what bond strength was attainable?
(Sorry to cross post, but no responses were forthcoming in the B&PV Engineering section)
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
RE: 1950s era stainless clad PV plate
Mike
That's the problem with the internet - nothing on earth could happen before it was invented.
How was that?
Thanks!
Sounds like you came by your moniker honestly
Sigma is not possible, and there seems too much ductility in the fracture event to believe 885°F embrittlement is significant. I suspect sulfidation - any comments?
