Mold Wizard NX8.5.1.3
Hi
When I Initialize a project everything looks fine until I want to change the size of the mold using the Mold Base Library I get this Error
filename must be unique within a data manager
could it be something in the spread sheets?
RE: Mold Wizard NX8.5.1.3
Quote (jamesdufour)
I'm not familiar with Moldwizard, but it sounds like you are trying to modify a library part? If so, you may need to perform a "save-as" on the part before you modify it. My best guess is that you can't modify a library part and save it with the same name.
www.nxjournaling.com
