Relay Coordination of Large Motor with Multilple Generators
I have a large motor equal in HP to one of the supply generators. There are four generators. How do you show coordination with the generators?
RE: Relay Coordination of Large Motor with Multilple Generators
On a TCC?
What coordination do you want to show? What are your protection systems? Generator, bus, and motor differential and there's nothing to worry about coordinating. If all you have is time overcurrent, well we can only wish you the best of luck.
