Bulk modulus for silicon based hydraulic fluid
Can anyone help me find a ball park number for the bulk modulus of a silicon based hydraulic fluid, Ximeter 200.
An engineer wants to put it in a cyclic damper at 1Hz with no accumulator and I need to determine the pressure increase with temperature.
It should be around 100kPa if I am lucky. I just cannot find the information anywhere.
RE: Bulk modulus for silicon based hydraulic fluid
http://www.clearcoproducts.com/pdf/library/Compres...
http://www.jacobsonchemicals.co.uk/pdfs/Silicone_F...
http://krayden.com/tds/dow_550_tds.pdf
http://www.tandfonline.com/doi/abs/10.1080/0569819...
You'll need to ballpark your fluid viscosity, but I'd guess you have something around 100 centistokes (cs) plus or minus 50, for a hydraulic fluid...luckily the curves flatten out above a few cs. Temperature effects may be trickier to pin down.
