HEC-RAS - CHANNEL DESIGN/MODIFICATION EDITOR
I'm a bit new to HEC-ras and I'm using the Channel Editor to replace existing cross sections with trapezoidal sections. I created templates to replace the setions and then I saved the info a new Geometry File. For some strange reason, n values are carried throughout the section as specified in the templates and I get run warnings. any thoughts are appreciated.
RE: HEC-RAS - CHANNEL DESIGN/MODIFICATION EDITOR
Not exactly sure what you mean by "n" values carried through; but, you can directly edit the roughness coeffs. Just look at the xsec editor and edit each xsec mannings roughness to what you are designing.
what you described is what i wanted to avoid. however, i was able to figure out that i needed to use the Channel Modification function with the original cross sections and that work out. thx
Oh yesI have used that in the past as well. There is an option to edit manning's roughness values by table that is relatively quick; of course, that depends on the number of cross sections. Glad you found the channel mod option.
