Decimals, Fractions & Rounding
Greetings,
Wanted to see what the opinions were on a couple frequently debated topics here at my workplace.
1. Decimals. Decimal equivelants of fractions are often used on engineering drawings. When you get a drawing that says cut to drill a hole at 0.19. Will you drill it at 0.19 or 0.1875?
2. Do you know all your fractions down to the 1/16ths? both 2 & 3 place decimals?
3. Would it be any simpler if drawings were given to you in fractions rather than decimals?
4. Do you scribe locations using caliper jaws or measure and use an actual scribe when working with soft steel or aluminum?
5. Do you do much locating/scribing using tape measure?
Any input will be greatly appreciated!
VS
VS
RE: Decimals, Fractions & Rounding
2. Yes, unfortunately.
3. Absolutely not. Fractions implies old English units. Metric doesn't use fractions. Stuff that I deal with is designed metric nowadays and you just don't do fractions on metric drawings.
4. Only if building something to tape-measure accuracy as opposed to CNC-mill accuracy.
5. Only if building something to tape-measure accuracy as opposed to CNC-mill accuracy.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
- I don't drill the hole, I do the drawing. I'll either show it as 0.1875" or 3/16", not 0.19".
2. Do you know all your fractions down to the 1/16ths? both 2 & 3 place decimals? Yes.
I'm not given the drawings, I give the drawings. Typically, we show linear dimensions in feet, inches, and 16ths, show plate thickness as decimal inches. With AutoCAD, you can dimension in cubits or furlongs, doesn't make any difference.
I don't do the shop work, the shop guys do that.
I don't do the shop work, but yes, tape measures are used frequently.
Since I do mostly structural drawings now, the drawing will show fractional inch measurements. Mechanical drawings will show the appropriate number of decimal places or fractional based on the desired tolerance from the standard tolerance block that are on my mechanical drawings.
3/16 is 0.1875 which is 4 decimal places. I am familiar with and regularly use down to 1/32nds in fraction and decimal form. I also work in decimal feet as necessary.
It depends on what you are trying to convey with the drawings. I suit the drawing to the job. Building a house has different tolerances than making the cabinets.
I use the caliper jaws to make a mark on the marking blue layer then go over with a scribe, prick punch, or center punch as necessary
It depends on the nature of the job. Some jobs require a scribe line, some require a sharp pencil or soapstone, while others may only require a magnum sharpie marker. I no longer do any layout work (other than hobby work), but I have done my fair share.
Generally, fractions imply greater tolerance than decimals. In my mind they can be laid out with a tape measure and marked with a dull pencil. Also, I once had a machinist ask me to PLEASE dimension the size of drilled holes with the same units he would see in his drill index. If I want him to drill a 7/16" hole, dimension it as 7/16", not .44". That made sense to me (and helps prevent errors) so I try to do that.
The most common practice for default decimal tolerances I have seen is this:
fractions = +/- 1/32
x.xx (two place) = +/- .01
x.xxx (three place) = +/- .005
You don't do this for this long without learning all your decimal conversions, at least down to 16th's.
All experienced designers and machinists know when they see .19 on a drawing that it means 3/16" is the nominal intended dimension and the tolerance is .010. Literally it would mean .1875 +/- .010. You don't dimension it as .1875 because the four place decimal implies a VERY tight tolerance.
My basic principle is this: I use the simplest possible method to accurately communicate the real need with the least chance of error. If I don't require a tight tolerance, I try not to imply one. If I do require a tight tolerance I make sure it is clearly stated.
There is no hard-and-fast rule about using either fractions or decimals exclusively. Both are appropriate for their intended purposes. For example, I'll dimension a wooden frame using fractions. A steel weldment with some machined surfaces would be a decimal default. My typical part drawing might have both fractions and decimals on it - again depending on the end purpose.
One last thing - I try to base my decimal display on the real required tolerances. For example, most stock sizes and cut lengths are relatively rough and can be shown in two-place decimals. However, two parts with matching hole patterns would require that the hole-to-hole dimensions be shown in three-place decimals.
Mike
For instance ASME Y14.5M-1994 lists millimeter and decimal inch dimensioning - it doesn't address fractional.
Well, I rarely do any making of actual parts but I would first consult the tolerance on the .19 dimensions, then take into account my process capability and then I'd select the appropriate drill bit - be it 3/16 or maybe a number 12 or 11... depending on the factors mentioned and drill bit availability. Despite what some above imply there is not a universal standard tolerance block that I'm aware of which can be assumed to be in play. In fact on drilled holes it's common to see the values from old AND10387 or similar used rather than just referring to tolerance block.
No, I'm OK but I won't claim to immediately know all of them off the top of my head though I can work it out pretty quick.
As to the other questions, like I said I'm not a machinist.
If you really care about the answers I'd be asking machinists and their associated manufacturing/production engineers - not necessarily most of the folk in this forum.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
My Machinery's Handbook, Edition 26, has a table showing all the drill types mixed together and sorted by size. For example, if I want to drill a Ø.200" hole, I need a Ø5.1mm drill, or a #8 drill. I wonder why it took so long for someone to think of this.
Don't forget that drills cut slightly oversize. If I am really serious about that Ø.200", the I will be tempted to use a #9 or a Ø5.0mm drill.
JHG
If you are really serious about 0.200" diameter, you should use a #10 drill (or smaller) and ream the hole, but I digress...
I agree that calling out drill sizes on shop drawings is ideal *IF* the preparer of the drawings is familiar with the subject. If not, it can have some costly consequences.
KENAT,
The tolerance block that I am familiar with is the one that I put in the title block of every drawing. It has a specific note that the tolerances in the block are in force unless noted otherwise.
So if the .19 is specified on your drawing great, but from the information given so far you don't know that your standard tol block and the OP's standard tol block are the same.
If dimensions are listed as fractions it implies using a tape/rule to measure.
I disagree with scribing lines off of a tape - use a layout rule.
