Adding straight lenght to entry port in Cabling
I have been able to route a number of harnesses in the Creo 2.0 Cabling application but I can not figure out how to maintain a certain straight length to each end of the harness. In other words, I need a minimum of 10mm straight length leaving each connector. Can anyone point me in the right direction?
Allen
Allen
RE: Adding straight lenght to entry port in Cabling
One other general question I have is, for those of you who use this application in CREO how do you set up the assemblies? I was thinking I would create a separate wiring assembly and add it to my top level assembly. Now, here is the tricky part. I tried doing an external shrinkwrap of the entire assembly and placing it in the wiring assembly. Then, I tried to run the wire from the points in the External Shrinkwrap but now it wont let me since CREO sees the External Shrinkwrap as one connector.
Cable Assembly
-Shrinkwrap
-Connector 1
-Connector 2
-Harness
Make Shrinkwrap default constraint, constrain connectors to Shrinkwrap, designate connectors and their entry ports, route cable from connector 1 to connector 2, route cable and place locations on Shrinkwrap.
