Corrosion boiler Stacker
Good day,
Looking for a product for which a boiler Stacker (inside) can be applied and also holds? Against corrosion, but it must be able to withstand higher temperatures as indicated on the data sheet, namely 350 ° C-400 ° C. And, it should be fully cured within 12 hours, so that the boiler can be restarted. The Ausfall-/Standzeit of the boiler is 12 hours ...
The product should brush - or even spray application. Most likely, only a 2-component product comes into question and must be preheated and then therefore can only be applied by spraying.
The surface to be treated is a total of only 15sqm.
Gert.
