Weld Design - AISC - Weld stress distribution factor
To account for weld stress distribution a welded connection can be designed for fpeak or 1.25 x favg.
Where is this stated in AISC. I see it the seismic design manual example problems when using the uniform force method but is this referenced in the the seismic design manual or AISC specification somewhere?
Thanks!
EIT
www.HowToEngineer.com
RE: Weld Design - AISC - Weld stress distribution factor
I don't think it is stated in the specification. However, the Steel Construction Manual (13th and 14th edition page 13-11 in the "available strength" section) states the welded connection should be designed for the greater of the peak stress and 1.25 times the average stress.
Thanks! Not sure how I didn't see this.
EIT
