pneumatic test for pad
hi
thanks for your attention
when welding of piping system pad's or pad of reinforced nozzle storage tank has finished ,
we use pneumatic test for pad.
which code & standard must be use to do it?
which code explain a procedure?
thanks alot
thanks alot
RE: pneumatic test for pad
Mike Halloran
Pembroke Pines, FL, USA
We probably are not nearby, but that's hard to establish, since you haven't told us where you are on the globe, and that certainly makes a difference in which codes apply.
Mike Halloran
