Non-Linear Pushover Analysis
Can someone please clarify some things for me. I am new to sap0000 and trying to figure out how to work with non linear analysis. For a simple introduction I just made a cantilever beam with a load at the tip. I defined a time-history function with a load that should start in the elastic range and end in the plastic range for the section and material I used.
I defined a frame hinge in at the base of the beam in order to get the plastic deformation in the right place.
My question is about what load case I should use. When I watch the CSI tutorials on youtube they use an acceleration in a non linear static analysis but the results I get for that dont make any sense. So I used the time history function I defined and got results that make some sense, the beam yields but not at the Fy=50 ksi (I used A992 steel).
Basically I just want someone to tell me how to get a cantilevered beam to behave non-linearly in the way calculate it should.
Thank you
Thank you
RE: Non-Linear Pushover Analysis
If you refer to "Accel" as a load type, in nonlinear load case window, then this is defined to tell the program that the lateral load will be incremental at say, 'UX' direction with a scale factor of either 1 or -1 (so that it will result to positive or negative displacements).
http://www.youtube.com/watch?v=CzqZVDse-eI
When setting up the load case, they use accel like you mentioned. Is this is only way to do this?
What exactly doesn't make sense in the results you mentioned in the first post? Because I believe there is some confusion of static nonlinear with transient nonlinear analysis.
-There are no frame hinges in this one (define->section properties->hinge properties...)
-One of your materials has a stress-strain curve to behave as tottaly elastic
-There is no nonlinear static analysis case but a direct integration one.The accel is the "Load Type" in a "Static Nonlinear" analysis,not in transient analysis.Pushover is a static analysis.
The video example is very clear on that.I suggest you perform it step by step,and then attempt to do pushover on your file.
