Open ended pipe.
Open ended pipe.
I am trying to calculate the airflow through open ended 0.125 inch ID vinyl tubes, 2 ft and 4 ft long with from 50 to 100 PSI on the other ends. It's for a unique application for a non profit organization.
RE: Open ended pipe.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
