1950s era stainless clad PV plate
Can any of you oldtimers recall what was the going technology for cladding 1/8" thick SS on steel plate? In this case it is grade 405 (ferritic SS) on an unknown grade of carbon steel; it is not welded.
If roll bond is the answer, what bond strength was attainable?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
