Part Cleanup Macro
Part Cleanup Macro
We deal with a lot of foreign data in NX and we have a nagging problem. When we cross over the imported solid with a mouse cursor, the model becomes highlighted in a reddish orange and does not go away. Someone pointed me to a command under File-Utilities-Part Cleanup..Remove Extraneous Highlighting check box. This command does the trick every time but is a buried command and to many clicks away.
I recorded a macro and assigned it to a button which works fine only the part that the macro was created against. Every other part I try to run this macro with throws up and error which can be cleared, but takes another two mouse clicks to remove the highlighting.
Does anyone have a working macro for this or any idea what I can do to make this macro "generic" across all part files?
Here is the error "Macro Out of Sync...Error at line number 60. Playback terminated. A dialog item recorded in the macro is causing a problem. Has the macro been played back from a different state? Has the dialog been modified?"
Line 60 in a text editor is a follows...OK -10 0 ! OK Callback
but who know where it starts counting.
Ryan
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
RE: Part Cleanup Macro
Try recording a journal, the following was created on NX 8.
CODE
www.nxjournaling.com
The journal seems to have done the trick.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
305 Leo St.
Tel: 937.224.0868
Fax: 937.224.1356
