Calculating removal of air humidy
A bit outside my area of work but I am mostly trying to understand some concepts. It seems most dehumidifiers rate performance in volume/time, not BTUs, watts, etc. Air conditioners are rated with BTUs cooling with no regard to air moisture.
I realize and have no problem calculating the dew point based on air temp, RH, pressure, etc. I also realize that simply passing air across an evap that has a surface temp below the dew point will condense the moisture. However, I have never been able to quantify the effects of an air conditioner in regards to separation of air cooling and water condensing.
What am I missing? Or am I simply over thinking this? I might need to dust off the thermo book...
RE: Calculating removal of air humidy
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
In short, would anyone have the calcs available to arrive at specific heat for air/water?
The dehumdifier values are based on standard conditions (i.e. 80°F and 70%RH and in that type of room it removes X gallons per hour etc.). this removal rate changes with space conditions rapidly.
