What is Stub reference error
Hi ,
NX 8.5 TC 8.3
We are seeing issues with some of the assemblies when trying to load gives "Stub Reference Error" .. Can any one please let me know what is the cause for this and what can resolve this situation..
If I load the assembly with partial loading turned off, then the assembly loads perfect..But I do not want to turn off the partial loading other wise it will take more time to load the assembly as the data for every component is also getting loaded to session..
The assemblies and components are usually exported and imported from team center database and to database using ugclone mechanism..
Can this be causing the stub reference error?
Thanks all in advance for the help and support..
