Get Minimun Distance
hi everybody
i have an issue, hope you can help me with this
well i have a product with abot 130 parts, and i need to know the distance between each part,
doing it manually is terrible, hope you can help me with this,
thank you
thank you
RE: Get Minimun Distance
As you are not looking off clash but distance, select the option with clearance and put the parameter to a large number. Also select option Between all components so it will check each part against all.
thank you so much for your answer
is there any way to do it in a macro?
CODE --> VBA
Private Function MeasureClash(MaxClearance As Double) As Double Dim MyDoc As Document Set MyDoc = CATIA.ActiveDocument Dim MyProduct As Product Set MyProduct = MyDoc.Product Dim Product1 As Product Dim Product2 As Product Set Product1 = MyProduct.Products.Item("Part1.1") Set Product2 = MyProduct.Products.Item("Part2.1") Dim MySelection As Selection Set MySelection = MyDoc.Selection MySelection.Clear Call MySelection.Add(Product1) Call MySelection.Add(Product2) Dim cClashes As Clashes Set cClashes = MyProduct.GetTechnologicalObject("Clashes") Dim MyClash As Clash Set MyClash = cClashes.AddFromSel MyClash.ComputationType = catClashComputationTypeInsideOne If MaxClearance > 0 Then MyClash.InterferenceType = catClashInterferenceTypeClearance MyClash.Clearance = MaxClearance Else MyClash.InterferenceType = catClashInterferenceTypeContact End If MyClash.Compute MySelection.Clear Dim i As Integer If MyClash.Conflicts.Count <> 0 Then For i = 1 To MyClash.Conflicts.Count Dim MyConflict As Conflict Set MyConflict = MyClash.Conflicts.Item(i) If MyConflict.Type = catConflictTypeClash Then MeasureClash = MyConflict.Value End If If MyConflict.Type = catConflictTypeClearance Then MeasureClash = MyConflict.Value End If If MyConflict.Type = catConflictTypeContact Then MeasureClash = MyConflict.Value End If Next Else MsgBox "Clearance Value > " + CStr(MaxClearance) MeasureClash = 3333 End If End Function Private Function MeasureDistance() As Double Dim MyDoc As Document Set MyDoc = CATIA.ActiveDocument Dim MyProduct As Product Set MyProduct = MyDoc.Product Dim Product1 As Product Dim Product2 As Product Set Product1 = MyProduct.Products.Item("Part1.1") Set Product2 = MyProduct.Products.Item("Part2.1") Dim MySelection As Selection Set MySelection = MyDoc.Selection MySelection.Clear Call MySelection.Add(Product1) Call MySelection.Add(Product2) Dim cDistances As Distances Set cDistances = MyProduct.GetTechnologicalObject("Distances") Dim MyDistance As Distance Set MyDistance = cDistances.AddFromSel MyDistance.ComputationType = catDistanceComputationTypeInsideOne MyDistance.MeasureType = catDistanceMeasureTypeMinimum MeasureDistance = MyDistance.Value MySelection.Clear End FunctionRE: Get Minimun Distance
thank you so much for this code, it really help me a lot
i wonder if, this code just work for products? or it can be used also to mesure between partbodies within a part?
This is a shame on Dessault's Part.
i will try different ways to find a solution for this.
thank you
