Windows edit attribute
thread561-332871: Journal - Show Attribute Value on TextBox (User Form)
I found this journal,
I can not add the same window
other attributes to be modified.
for example:
CATALOG
MATERIAL
MW_STOCK_SIZE
and maybe highlight the name of
part in the window.
if someone wants to help would be great
nx7.5.3.3
xp 64bit
for example:
CATALOG
MATERIAL
MW_STOCK_SIZE
part in the window.
nx7.5.3.3
xp 64bit
RE: Windows edit attribute
CODE
www.nxjournaling.com
It's possible to see only the file name?
The full pach is so long that the name part is outside of the window
(in real is better for me to see only the name part)
Thank in advance.
CODE
and change it to:
CODE
