Heat transfer though anchor bolt
We have a slurry tank heated to 135F. The slab is 36 in. and the 2 in. diameter anchor bolt is embedded 24 in. into the slab. Underneath the slab is a pump room we are assuming is kept at 80F. We need to know at what point the anchor bolt temperature drops to 120F to start using epoxy.
Is there a simplified method to do this calculation without having to do a finite element analysis?
RE: Heat transfer though anchor bolt
Is there an opportunity to use a bolt with a mechanical type of anchorage? If in-place field adjustment is what you are looking for, I've had some luck with DECO adjustable anchors. www.decomfg.com
