NX - cant change reference set to KOERPER
RE: NX - cant change reference set to KOERPER
When we have that error we have to open the part that we want to change to reference set of then open our assembly as "structure only" and we are allowed to change the reference set.
Steve
NX 7.5.5.4
Maybe i don't understand something or i've did sth wrong... but i've had still the same error message.
OK, try this.
1. New session of NX
2. Open part that you wanted to change the ref set of in your assembly (196098.prt).
3. Run file->utilities->part cleanup (run all except the section that says "use caution")
4. Change load options to "structure only"
5. Open assembly 196097.prt
6. repeat step 3.
7. Try to change ref set of 196098.prt
Steve
NX 7.5.5.4
It works !!! Thank You very much, Great solution, thank You for Your help.
I greet YOU
