tank painting
tank painting
tank painting
What's the type of tank painting which used from inner and outer surfaces?
RE: tank painting
The storage tank painting is required by several conditions.
Eliminate the first, obvious one, you don't normally paint the stainless steel tank except special circumstances.
The carbon steel tank should be painted on the exterior to withstand the local weather conditions. The type of paint depends on the location where the tank is operating, a typical paint system includes a primer to provide strong adherence of the subsequent paint layers and also to provide the primary corrosion resistance. It could be a high zinc content primer or a suitable epoxy paint (basically inorganic or organic primer). Apply then a suitable intermediate paint if required and a final top coat for corrosion protection, UV protection, etc.
The internal coating paint depends on the fluid stored, the paint supplier will tell you which is the suitable paint and the application method specific for your application. Sometimes you need protection against corrosive fluids, sometimes abrasive resistant paint, perhaps a combination of the corrosion and abrasion resistance.
You really need to talk to the paint supplier for guidance, since you have to request guarantees for the selected paint suitability in your application.
RE: tank painting
I agree with gr2vessels about contacting the paint manufacturers and distributors. Manufacturers and distributors have specification literature on their paints, so before you embark on detailing purchase orders contact them and be sure to follow their procedures explicitly otherwise you may forfeit their warranties.
