how to update expression from external spreadsheet
dear
i have make the spreadsheet which includes the all the expression of piston .so how to connect this expression to the nx 6 model so expression change model will be change
RE: how to update expression from external spreadsheet
While in the Expression dialog, select the f(x) icon at the bottom Left corner and when the next dialog opens, from the drop-down list under 'Choose a Category', select the 'spreadsheet' option. Here you will find four functions for reading data from external spreadsheets. When you selct a function, if you select the [?] icon on the right you'll be taken to the documentation showing you how to use that function.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
