1PH motor fail to start, locked rotor amps, possibly rotor touching stator
Got stuck putting bearings in a table saw for someone. The motor is the oddest thing I have ever seen. The Al case splits all the way down axially and the stator is removed from the cases. Technically, I do not believe it is supposed to be serviced. The stator and bearings were bedded in epoxy.
Any, I was with the saw when it failed. It was running doing light plastic cuts solid for 1hr. It just got a vibration very quickly and created some wood smoke from being hot. The bearings really were not that bad and certainly did not cause the vibration.
I found a bad run cap. changed that and the bearings. Motor will not start. Growls, shaft turns a bit, pulls about 5-6x FLA. We obviously don't leave it in this state for even a full second.
I don't know that I have ever had a motor's rotor contact the stator but in this design, I believe we are experiencing some of that BUT I am really unsure if that would really cause this problem? This should not cause a loss of magnetic flux should it? If contact with the stator would not cause a locked rotor state, any other ideas? I have an ESR meter as well and I show the start cap is still good, potential relay is normally close right now, bleed resistor is working, etc.
I don't have a specific diagram for this motor but it seems odd. It has a non contact inductive coil on the tail I assume to operate the potential relay. Never seen that. Usually a switch or relay operates off of start winding.
RE: 1PH motor fail to start, locked rotor amps, possibly rotor touching stator
"Will work for (the memory of) salami"
I was looking at diagrams for standard dual voltage single phase motors but they have 6 wires, this one has 5. I cannot seem to figure out which point they have tied to make the 5 wires. I figured T4/T5 but the whole thing just tests strange. Just when I think I have my main winding wires, something else conducts. Neither side of the start cap connect directly to power, they go to motor leads.
Is there anything we can inspect on the rotor aside from growler testing?
