equivalent k value (spring and tyre stiffness)
Im trying to determine the correct equivalent k values for the spring rates for the sprung and unsprung mass.
For instance, is kspring + ktyre correct for the unsprung part (when trying to calc. the critical damping for example)?
Gracias sunshine
RE: equivalent k value (spring and tyre stiffness)
Thanks again Greg smarty
I also found great info on kaztechnologies regarding this
Twin tyre would then also simply be kspring + 2 x ktyre right.
