Tooling Componet Templates - Renaming upon insertion into ass'y
I've got a library of parts I've built up over time.
Shoulder bolts...
Punches...
Springs...
Some small assy's...
I really only maintain one base template for each of the above examples. Once inserted / mated into position it's very flexible. I can change expression values such as diameter and length and they update... even report back to the BOM what those sizes are. Not a bad method for tooling. So often a spring will change size a couple of times till you have everything in the design worked out.
My gripe is I've got to manually copy these templates into the job folder as I go. Can't drag and drop or the mods made after insertion go back to the library source part.
So...
Is there a practical way or method of drag and drop, or something similar that allows a rename and placement into the active job folder?
If so I would like to build an entire library / system around it.
Thanks in advance for any help!
Dave
Shoulder bolts...
Punches...
Springs...
So...
Dave
RE: Tooling Componet Templates - Renaming upon insertion into ass'y
Add them to a reuse library?
Deformable components?
www.nxjournaling.com
Half my problem is being so strapped for time in this fast paced business... that's why I'm asking for suggestions here first.
Whatever emerges from this thread is where I'll put the time I do have.
Do you have the machinery library installed? If so, your library could work something like that.
If you don't have it installed/have not used it; imagine opening a navigator panel find a component type, drag it into your assembly and a dialog pops up that asks desired dimensions, component is called up (or created as necessary) and added to your assembly.
Sounds like I need to look into part families first.
Any direction I can find here should help. I've started down this road a couple of times but always get de-railed.
If there is any reading mat'ls available or especially file examples of how this is done please share. I really want to get it done this time. No stumbling around in the dark!
Thanks for being responsive Cowski.
NX 8.5, No Team Center
Dave
The part needs to:
Reside in the folder the assembly is in after placement...
A unique name given upon insertion...
Be fully editable after placement (Ideally the conventional way in the part navigator...
And a wish: Can it be done with a small assy? Meaning the part being inserted contains a few parts of its on. Maybe this one isn't suited for the part family thing??
Can the reuse handle all of the above???
Dave
I seem to have it working... but the parts i place in my ass'y won't load after reopening.
Am I missing an Environment Variable????
I find the docs and available help on deploying this vague and at times cryptic.
You can set the directory in your customer defaults: Gateway -> Reuse library -> reusable component tab -> part family save directory.
I've done that... and the parts I've inserted into my ass'y are residing in the folder I've specified there.
But when I close up the design and re-open they aren't found so they don't load up.
I have to be missing something obvious. How about my Load and Save Options?? I'm currently set to Load from "Folder" Maybe I need to set it to "From Search Folder"?
I'm running in Native mode and installed my library through: Library Management -> Add Library
Baffled here. This should be easy and fairly strait forward. But I've found myself spending hours in the Help files, Downloaded docs from GTAC and this forum. Its tiring!
But I'm determined to figure both this problem out and master this add on!
Dave
