Location of System Options Settings - Any Interest?
3
SBaugh (Mechanical)
I have gone through the System options and I have found at least 95% of all the system options, where they are at in the Registry and how they work. I have been considering writing an article or documentation that would give this information to everyone, but I don't know if there is much interest in this. I personally have an interest in this as I am the CAD Admin here at Berry and I want certain options on and some off. I don't want to export my system options from SW, as it contains crap the users don't need and it makes reading a Settings file much harder.
To explain this further, if you copy everything from an exported settings file and paste it into a Word Document. Change the line spacing to "single" and "Do not add spaces", you will have approximately 99+/- pages of registry information just from that exported settings file.
If you create your own like I did using the same Word Document Settings as above, I have total of 3 pages.
Three pages of settings is a much easier than sifting through 100 pages of information that is not needed nor will it be used. 95% of that information will be installed as default anyway. I am only concerned about a few selected items within the System Options.
I am curious if there is anyone interested in knowing this information... I don't see a lot of posts on it, so I don't know if there are any other CAD Admins that really care to know this.
If you are interested, post here and let me know... I will find away to publish this for everyone to see, problem is explaining some of it and how it works, that might require a few videos.
Thanks for reading,
Thanks for reading,
Scott Baugh, CSWP
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: Location of System Options Settings - Any Interest?
Dan
www.eltronresearch.com
Dan's Blog
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
www.scottjbaugh.com
Scott Baugh, CSWP
www.scottjbaugh.com
Chris
SolidWorks 13
ctopher's home
SolidWorks Legion
Weevoe
C
Glad to see there is so much interest in this topic!
Scott Baugh, CSWP
www.scottjbaugh.com
